R
Rozman
This is a really dumb one. I have an older Mackie 1202 (not a VLZ) and an FMR RNC compressor. I can't find the manual for the RNC, but I did download the quickstart guide. However, I am apparently too ignorant to hook up the darn thing properly. I have a Hosa Y cable that is TRS on one end and TS on each of the two other ends. I plugged the TRS end into the appropriate channel insert on the Mackie board and plugged the two TS ends into the left and right outputs of the RNC, respectively. And, voila, nothing! There is no sound out of the mike until I hit the bypass on the compressor. Do I need a Y cable that is TRS on all three ends? There is some verbiage in the FMR Quick Start Guide that says you can't hook up the RNC to balanced lines with TRS 1/4" plugs. But it also says that you CAN hook up to TRS inserts on a console. I am SOOOO confused!!! Is my Hosa Y cable balanced? I have no idea. I can't even get off the starting line.
