dachay2tnr
One Hit Wonder
Not sure where to turn for this one, but I’ll start in the midi forum. Last night I recorded a midi drum track into Sonar using a Roland TD-11 set. The Roland has a Midi Out connection, as well as a USB connection. I recorded using the Midi Out connected to the midi in on my audio interface. It all went fine and the track was recorded with no issues.
Now however, I want to play that track back to the TD-11 and ultimately record it as audio. There is no Midi In port on the TD-11, so I assume I have to use the USB port. When I plugged the TD-11 into my computer‘s USB directly, I got a popup in Sonar telling me a new device was available (TD-11). I selected that as my output in the Sonar track and played the track. But I am getting absolutely no sound from the TD-11. The track in Sonar appears to be playing correctly as I see the meters moving. Both Sonar and the TD-11 are set to MIDI Channel 10. Any thoughts? It seems I am missing a simple setting, but for the life of me I can’t figure it out. Thanks in advance for any help.
