sowpunk
Hey everyone!
I just purchased a Phonic Helix 18 Firewire. Everything works great
With one exception...
I am using Cubase SX3 to test out the board. So I set track one in Cubase to recieve from Channel One on the mixing desk. I arm the track and record myself speaking into the mic.
The sound is present
So I know I am recording. Also, when I export the file I can play it back in iTunes and hear what I have recorded. However... the monitoring and playback are not working in Cubase. I have two active monitors connected to the "Control Room Out" on the mixer. This does allow me to hear the mix in real time - but not in playback.
I tried to change the outputs to my computer soundcard but I can only select the Phonic Outputs due to the ASIO driver.
I am happy for the playback to come through the mixer via firewire and then into the monitors but I can't seem to get this working.
Any help is greatly appreciated!
With one exception...I am using Cubase SX3 to test out the board. So I set track one in Cubase to recieve from Channel One on the mixing desk. I arm the track and record myself speaking into the mic.
So I know I am recording. Also, when I export the file I can play it back in iTunes and hear what I have recorded. However... the monitoring and playback are not working in Cubase. I have two active monitors connected to the "Control Room Out" on the mixer. This does allow me to hear the mix in real time - but not in playback.I tried to change the outputs to my computer soundcard but I can only select the Phonic Outputs due to the ASIO driver.
