C
C-1st
is the best processor (Pentium or Athlon) to use? What speed? How much ram do I need? How big a hard drive do I need?
C-1st said:What is the best processor (Pentium or Athlon) to use?
C-1st said:Whats your budget?
$ not an issue.
Wow - I wish I had your bank account! I'm going to take this with a big grain of salt, because I think what you are really asking about is a dream system, then you'll join the rest of us and build something reasonable.
What are you recording (44.1, 96 kHz?) 96
OK, that's going to produce a lot bigger files on the disk.
What is your (planned) interface to the computer? Already have Audiophile 2496
I don't know much about this particular interface - looks like a reasonable 4 in/4 out interface. I'll assume that this works well with Cakewalk products unless anyone speaks up.
How many channels will you be recording/playing back at once?
Record on standalone. Playback & mix 16 tracks
Sounds like a reasonable expectation in terms of number of tracks. This should be very achievable.
How many effects? Mainly use outboard effects.
This is great news from a CPU loading point of view.
How long will your recordings be...how much audio do you want to store on the hard disk at one time? 200 or 300 songs
Oops! Lets see.... 3 1/2 minute song, 16 tracks, 96 kHz sample rate, 24-bit samples (stored as 32-bit) gives us about 1.3 Gigabytes per song. If your songs are 5 minutes long, thats about 1.8 Gigabytes per song. I find that I usually end up with about 5 copies of each song through the working process (your process could vary, but I'm a big believer in saving my work and backing up -- I've been burned before.) So, figure 10 Gigabytes per song or so. For a 120 Gig hard drive, that gives about 12 songs, or one solid album's worth.
What kind of backup are you planning? ??? I have a CD Burner if that is what you are asking?
Ahhh, another issue. I strongly, highly, intensely recommend you plan on how you want to save and backup your music long term as part of this. A CD burner *can* be used, but its a bit of a pain. Typically, you can write a bundled file, then zip it, then burn a CD. The unzipped bundled file won't fit. A much easier solution these days is a DVD writer. Right now, I'm recommending DVD+R/DVD+RW for speed and compatibility reasons. It looks like that's the DVD variant that is winning in the marketplace.
LEADGTRPLAYR said:This would be my first time in here asking for help instead of trying to help others(which i love to do)!!ok now problem,i have a P4system,running raid drives both the Western Digital 120gig., 8 mb buffer drives,a motu896(firewire)..computer smokes so no problems there...But yet there is,whenever i record @24-bit i can only get in about a 3 minutes and then kaput audio dropout occures,now i know a good deal about this bull but whenever i use my other machine which is a 2.2ghzP4 with just one drive it's all good,the other machine btw is a 2.5ghz..so i guess my question would be why would i get an audio dropout with a slower machine???have chacked all my settings they are the same in both machines????
laptoppop said:
Windows XP Pro (NOT home edition) (Tweaked/minimized for audio)
James Argo said:
Do you know the difference between two (Pro and Home) in audio working environment ? I do agree with the rest of your post, they make sense, and reasonable, but "Win XP Pro (NOT Home edition)" ? I didn't think that'll give you any difference... in audio terms, they both do just fine. Unless you will use Double Processor, then use Pro edition. Other way, Home, Pro, or Developer edition will be good.![]()
brzilian said:
I agree. There is no difference whatsoever between Pro and Home unless you either have a dual processor system or need more advanced networking functionality.
I have used both with DAW's and there have been do discrepancies or reasons not to just stick with Home. After all, it is almost $100 cheaper than Pro.
Fair enough. I was basing my comments on some device driver/latency issues that I have heard about. I do not have the first hand knowledge of the issues. What I was told was that the kernel was very slightly different at the lowest levels, with XP Pro being better suited to server/audio work. I do trust my sources, but again, I don't have first hand knowledge of the kernel. I do know that if you are setting up multiple users, Pro is nicer with fast user switching, but for an audio machine you'd be wanting to run lean and mean anyway.
Also laptoppop erroneously pointed out that the Audiophile is a 4in/4 out card. It does indeed have 2 stereo inputs and outputs,but one pair is digital/SPDIF so unless you have a device with digital outs and one with analog, you will be recording 2 tracks (or one stereo pair) at a time.
You got me there. :>) I was just going off of a 2 second read from a Google source - which is why I invited others to chime in.
The bigger picture to take into consideration is that HS2002 can only record 2 tracks simultaneously at any time. If you have a card with more inputs and want to record more tracks in one take, you will have to move up to Sonar.
LEADGTRPLAYR said:Well i'd like the chance to respond to James,FIRST OF ALL,Iwas talking about XP PRO,I am no beginner at this and would not even consider suggesting any home version of anything,Second of all I was recommending W2KPRO(that stands for windows 2000 professional)DO YOU KNOW THE DIFFERENCE???,AND LAST OF ALL,I have had a shitty time with XP and all it's glitches,bugs,driver issues,etc.Everyone i know who has used XP/PRO has also has a confirmed nothing but problems getting this and that to work,So to all of them i suggest W2K/PRO(WINDOWS 2000 PROFESSIONAL)and would'nt yaknow all of their shitty XP problems went away and instead of them fighting with thier computers,they all now thank me and tell me yeah looks alot like 98,but runs way better,no lockups,no blue screens.........HAVE FUN WITH YOUR XP/PRO/HOME,WHATEVER?? BTW WITH XP/PRO I AM SO SICK OF HEARING YEAH ONCE YOU GET IT ALL SET UP WORX GREAT,WELL YOU GUYS KEEP ON TWEAKING XP,WHILE I KEEP ON RECORDING......Don't want u guys hopping on me cause someone OBVIOUSLY,has mistaken me!!!
