tkingen
Djembes Rock
Warhead said:Stop making sense.![]()
War
War,
Of course the message was right on the money. But to hell with the punk condescending tone.
Btw, have you seen the book?
War
TravisinFlorida said:Here's one to check out too: http://www.chooseamicwithyourmindyousillydildo.com
chessrock said:You use the freakin' mics and you learn what they sound like. Then you pick the one you think will work best. If it doesn't work, then you try another one. Jeezus, dude. How do you pick a tie or a pair of shoes?
tkingen said:Say you already have a nice mic cabinet that pretty much covers most of the recording situations you may have. How do you decide which mic would be a good choice for a given job?
I'm not talking about the hit or miss method of just throwing a bunch of different mics up to see which one sounds the best. What I mean is what's your thought process in narrowing down the choices to begin with? If you own 15 mics and you are recording a silky soprano voice which mic qualities are you looking for to record that voice? A chesty baritone? A mahogany parlor guitar with light gauge strings? A rosewood dreadnaught with heavy strings? A snare with brushes? A full kit?
I'm not specifically looking for an answer to the above examples, but more of the personal philosophy or science that helps to make the decision.
tkingen said:But to hell with the punk condescending tone.
chessrock said:Me? ? Condescending tone? ? NEVER !
Alright, I'll throw you a bone. When considering the mic'ing of a given source, first ask yourself ... are you trying to pick up the totality of the instrument? Or are you trying to pick up a narrow part of the instrument / source?
Take drums as an example ... are you trying to mic the whole kit or just the tom-tom? Do you want to pick up what the entire guitar sounds like ... or do you want to focus / emphasize what it sounds like at the 12th fret? Maybe you feel that what is happening, specifically, at the 12th fret will help the guitar track fit better in the context of your mix, or that it will help you achieve a particular sound that you're striving for? On the other hand, perhaps there are subtle nuances happening all over the body of the guitar that can only be captured from a wider vantage point.
The reason this is important is because certain mics will snap in to focus more at certain distances. An SM57, for example, is really more of a close-up mic (Have you ever noticed how it's always jammed up against something?) It's not generally the best distant mic; most dynamics aren't, with some exceptions, obviously. The farther back you move a particular mic, the more important off-axis response becomes. Something with a wider pattern will obviously be more at home picking a slightly bigger picture of the source; sort of like a wider-angle lense. Smaller diaphragms will tend to sound more natural in that role, as they will usually report off-axis information much more accurately than their larger-diaphragm counterparts (and this is another over-generalized statement).
The next thing I like to take in to consideration is accuracy and transient response. Think about it like this: If my ear were to be placed right up against this source being struck or played at extreme volumes, is it going to be a painful/ unpleasant experience? If the answer to that question is "Yes," then you might consider using a softer, slower, less accurate mic. Like a dynamic or a ribbon, maybe a more vintage style tube mic, etc. For example; a screaming death metal singer might be unpleasant at full volume with the singer's mouth right up against your ear. A harsh, cheap cymbal crash might have the same unpleasant effect.
On the other hand, if your answer to that question is "NO" as in the case of a softly strummed harp, a smooth jazz bass, or a classical guitar ... then in these cases you might choose a more accurate microphone; like a transformerless condenser with a thinner or smaller, more responsive diaphragm. Another question along the same lines: How important is the sound of the fingers picking the strings, versus the sound of the notes those strings are playing? How important is the impact of the stick hitting the drum skin versus the tone / boddy of the drum it's hitting? Very very generally speaking, the more important the notes, tone and body of the instrument are (relatively speaking), the less important the speed and accuracy of the mic becomes.
Lastly, you're always going to want to consider the frequency response curve of the mic, and how that might interact with the source. In a very overly-simplified explanation .. when mic'ing a very bright and strident source, you might consider using a darker mic ... or with a dull / dark sounding source, you might want to use a brighter mic. But more generally speaking ... ask yourself what, if anything, do you want to emphasize about the source, and what do you want to de-emphasize? And what mics in my collection will be likely to emphasize that which I want more of, and de-emphasize that which I want less of?
