Phasing Problems with Insert Effects
  • Thread starter Thread starter Jeffro Hunter
J
Jeffro Hunter
I am having a problem with phasing problems while inserting effects during mixdown. What I am doing is running a send to my Roalnd Br-8 and using the effects from my BR-8 to return to my board. When I play back my tape with effects applied, I get a phasing problem. If I turn down the main fader and just use the effects send, it seems to correct the problem, but I would like to mix in some dry signal without a phasing problem. I also tried sending to my computer and using my plug-in effects with the same results. I tried to make sure any e.q. settings on my BR-8 were flat to avoid eq conflicts with my board to no avail. Any help would be greatly appreciated. :confused:
