W
		willow
phase...
recording - how do you avoid phasing (mic placements)and when do you mess with the phase inversion option? are there certain settings that are better before recording?
playback- how do you know when to set a certain track with inversion? for example.. i have a song that was recorded with 8 mics. an engineer heard this song a while back and he said that there were phasing problems in the drum tracks. how did he go about distinguishing them and how would you correct it? is it a matter of finding a track that sounds weak and just inverting that one track?
meters- i remember recording on reel-to-reel and i was pretty good at getting good input levels just by hitting in the red only on quick peaks
recording- in sonar, i usually let the meters go to the red occasionally on the fast peaks. (not all the way... -6 area) should i be recording a little hotter?
playback- when i play all the tracks.. the master is too loud when it is set on 0 db? would it be best to set all the tracks at levels so that the master is showing optimum levels at 0 db?
i hope you understand the questions the way i'm asking them..
any info and "rules of thumb" would be appreciated
gracias
gracias
