thanks.
i'm worrying about it because most mic preamps put out 48v, but the one i am thinking of buying puts out 12v.
12v is very near the lower range of many mics, isn't it?
presumably they stop working alltogether below that... so are there any differences in the sound depending on the voltage used? is the typical condenser mic more sensitive / sound better at 48v? or what?
(i would have thought the high voltage standard was adopted for a reason, like maybe it produces more signal? and then you have your electret-condenser mic elements -- that operate on low voltage, but that have to be compatible with the 48v phantom power, so the voltage must be dropped internally, meaning that if you go to 12v, it gets dropped even more... )
so i guess the question is, for those of you that have used both 12v and 48v phantom power supplies, do you ever notice any difference with any of your condenser and electret mics? if so, is the difference associated with particular brands or models? or is it rare for a mic to work fine at 48v and not at 12v?
