frederic
Thanks to the speedy services of UPS, I now have a small box of white LEDs.
I like LEDs, a lot. They draw very little current, they are fairly bright nowadays, and they are available in many colors. Add to that they are very small.
So, I have a box of white LEDs, I wired up a simple circuit I designed, which limits the current to them, as well as varies the pulsewidth from 5% to 95%, thus changing the brightness from nearly useless to fairly bright.
I'm experimenting with these because halogen lighting is very hot to be near, even with smaller bulbs. Also, with a 7' ceiling height, lights hanging down eat up valuable headroom since both my wife and I are 5'11" or thereabouts. The heat issue is important for several reasons - to sink a fixture in my ceiling, will mean that the electrical box will be to close to the wood sheathing that the slate roof is on. While probably not a bad thing per se, the wood is 61 years old and i worry about an eventual short, and a fire, lighting up my studio brilliantly.
Maybe paranoia, but I'm thinking low voltage, low current, low heat LED's might be an interesting way of lighting the studio and not requiring space above or below the ceiling line.
What do you guys think? Obviously less effective for those of you with the splendor of 20' ceilings, but for guys like me with low ceilings and nasty slants on the same, it might be a good solution.
I chose to buy individual LED's because the commercial 120V LED-filled lightbulbs seem to be 45 bucks or more. True, they last 100 years, but I'm thinking this might be better ultimately.
Time will tell I guess
