TelePaul
J to the R O C
Hi. Is the only way to monitor the input signal in SE 3 via the peak level indicator below each mixer channel?
Farview said:Yup. That's it. Usually, you would monitor the signal using the meters on your preamps or mixer.
-18 to -12 average level. Hold a power chord and set the level to -18. Have the singer hold a loud note and set the level for -18. With drums and other percussion, just get the peaks somewhere around -6 tops.TelePaul said:Thank you Farview. As it happens, the meters on my soundcard are a simple LED affair; if the signal is being picked up, a light goes green. If a signal is overloading, a light goes red. I should be aiming for -18 to -12 right?
Farview said:With a distorted guitar, hold a power chord. Set the level for -18dbfs
With a Vocalist, have them hold a note. Set the level for -18dbfs
With instruments that have long sustained sounds, sustain it and set it for -18dbfs (or just use the VU meter on the preamp or mixer if it has one)
With drums, set the peak to -6dbfs
With instruments with a lot of attack and little sustain, set the peak level to -6dbFS.
sirslurpee said:That is a very well explained and straight forward guide to go by... I'm gonna have to try that since lately I have been recording almost everything way louder than that with not-so-satisfactory results...
Thanks![]()
Most rappers, xylophone....anything you hit with a stick or hammer.TelePaul said:yeah same...Farview, can you give some examples of instruments other than drums that have lots of attack but little decay?
Farview said:Most rappers, xylophone....anything you hit with a stick or hammer.
Classic...
