>>>>>>>>>(Just trying to get a visual...) Is latency the amount of space between the time I click the mouse to the time my command is recognized? If it is, is this a problem with the software or a slower system?
The most common problem with latency as far as I can tell seems to occur when a midi track plays back off time with the rest of the audio tracks.....or when one or a number of tracks midi or audio are off time when playing back......This could effect your ability to get a "good take" when over dubbing and to mix accurately etc..etc....never mind the fact that you don't want to burn a CD that sounds all off time......it presents a number of problems..However, I have heard enough tunes in the mp3 clinic to determine that this is not a very common problem..or at least not one that can't be overcome...And like I said, I never had to deal with it anyway.....To answer the second question, It
is a hardware problem and not a software problem.
>>>>>>>>As an aside, is it just as easy to "punch" on computer as it is on a standalone unit? Could latency be a potential problem with punching in at the right moment?
You aren't going to have any problems punching in with a computer infact the accuracy of punching in on a computer is greatly improved upon.....you are able to type the exact time, (commonly reffered to in some programs as the "now time") that you want to punch in and the computer will punch you in at that exact time...........I'm not sure how this works on a standalone, however, compared to the older analog days "punching in" is greatly improved in terms of getting that punch in at the exact moment you need it to occur.
>>>>>>>>>>>>>>>Wascal, you had mentioned you have a stand-alone but use software to master. Have you had good luck with this setup? What are you using? The heading of my post says, PC vs. Worskstation, but I have not really thought about combining the two.
I know I'm not wascal but I'll answer this anyhow
.....This is also an option......however all those aforementioned problems with recording on computer...ie latency...losing work..etc...etc...are all factors with this route as well.....So if you are using you're computer for editing and everything anyhow without any problems then really the only reason to use a stand alone digital workstation is out of personal preference.....i.e.....wascal....saying he doesn't want the computer interfering with his creative process.....which is ridiculous as far as I'm concerned...sounds like something a Ludite would say.....no offense wascal....this debate is all in good fun
