Stealthtech
LOGIC ABUSER
OK guys, here's a reply I got from a Logic Forum:
posted 03-07-2002 10:05 AM
@Stealthtech:
You have 2 HDs. That's fine: reserve one for all your audio-files and samples.
On the other one, you should create 3-4 partitions:
1) multimedia OS
2) music OS - don't forget: no printer, modem, scanner, internet, AntiVirus,... (deactivate in system-control all the unnecessary hardware-components)
3) a partition only for the swap-file of your audio-OS (the swap-file size should have double size of physical RAM, in your case 512MB)
4)if you don'T want to use your audiofiles-HD for data exchange between the two OSs, you should create a 4th partition that is visible to both OS. On this small partition, you can store files, that you want to transfer from one OS to another (for example music tutorials, tools, drivers, samples downloaded from internet and needed on the music-OS).
Important:
make the partition of the music-OS invisible for the multimedia-OS: if it's infected by a virus, than the audio-OS is safe. If possible, also disable in the multimedia-OS the IDE channel to which the audio-files HD is connected. So it's not possible to access this HD from the multimedia-OS (-> need 4th partition for data exchange between the two OS)
Powerquest's PartitionMagic & BootMagic lets you make all the changes you need, without reinstalling.
My computer was infected by viruses several times (4-5 times) but at the worst case, i only had to reinstall the multimedia-OS.
@Stealthtech:
1) multimedia OS
Important:
