jamtheguitarman
At the moment, im running an old socket 754 AMD64 3400+ 2gig RAM system and need to build a new one. My plan is to build the new system and use my current system as a slave.
Antec Sonata Designer - With 500W EarthWatts PSU - £76
ASUS P5K-E/WIFI-AP AiLifestyle Series P35 Socket 775 Socket eSATA 8 channel Audio ATX Motherboard - £94
Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (2x4MB (4MB per core pair) Retail Boxed Processor - £168
Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 Memory C5(5-5-5-18) - £80
Sapphire HD 3850 Pro 256MB GDDR3 Dual DVI TVO PCI-E Graphics Card - £104
Seagate ST3500630AS 500GB Hard Drive SATAII 16MB Cache 7200RPM - OEM - £67
Samsung SH-S203B 20X DVD±RW/RAM / DL Serial ATA Black Bare Drive - OEM - £18
Zonet 4 Port KVM Switch with 4 Cables - £15
Thoughts?
My current soundcard is an Maudio delta 44 which i would keep and use FX teleport to join the systems.
Im a bit fuzzy as to what to do with my hard drives. I currently have 1 system drive, 1 audio drive and 1 samples drive (with EWGXP and Reaktor being my main instruments). Should i transfer the audio and samples drive to my new machine and then use a brand new system drive and just reinstall Cubase....etc leaving my current system drive in the old machine to run as the slave.
Im undecided over which OS to get, Vista 64bit? stick with XP?
I wont be running 64 bit applications right away, not until EW Play comes out.
Thanks for any help
Thoughts?
Thanks for any help
