RICK FITZPATRICK
it would resonate at a higher frequency, even if it were twice as long.
HUH? WHAT would resonate? Resistance absorption materials do NOT resonate nor absorb by resonance. They absorb by resistance to molecule movement within the material, which creates friction, which translates to energy conversion to heat. Don't count on heating the house though
Different absorption coefficients at different frequencies are due to 1/4 wavelength/incident angle/diffraction principles. Using absorption materials in the corners increase Low frequency absorption due to low frequency wavelengths approaching the room dimensions terminating in the corners(fluctuating pressure zones), and the variable depth of the absorber at corners. Impedence mismatch at the edges contribute to additional absorption benifits because of the "edge effect", REGARDLESS if the edges are exposed. At least this is my understanding. Should an expert disagree, I'm all ears.fitZ
