Pan to mixing . pls advise me
  • Thread starter Thread starter Papoola
P
Papoola
Hello, as I proceed in the next step of my production I have additional questions.
I have a Korg D 16 multitrack recorder that has 8 single tracks named 1 to 8 with Pan control and paired tracks named 9/10-11/12-13/14-15/16 with Pan control named balance.
Actually I have recorded stereo sounds on paired tracks (i.e. 9/10 - 11/12 - 13/14 etc etc). Additionally I have some other mono sounds (from the mono exit of the synth) recorded on the remaining single tracks (i.e 6,7,8)
Now, I am bouncing all above tracks on track 1&2 to be my final production as left channel (track 1) and right channel (track 2).
Can you please confirm or deny the following procedure??
1) I will put in play all the tracks except 1&2 that will be in record mode
2)Will check levels and set the machine to bounce mode
3) To mantain stereo sounds of tracks 9/10, 11/12, 13/14, 15/16 i will keep the pan in this case named "balance" centered.
4) The other sounds of tracks 7, 8 I can decide where to pan
depending from the sound, instrument etc etc
5) After recording, to produce the stereo master, Tracks 1 SHALL BE fully panned to the left and track 2 SHALL BE fully panned on right ??
Am I ok, or better go for a musical course ??
Pls be so kind once more to correct me
Tks
