F
flat5th
I am a complete novice using Cool Edit Pro. What I am trying to do is feed old analog live and studio tapes in and then do some re mixing. I save them as a wave file and then try to burn to a CD. My CD burning program (Adaptec) tells me there are output errors and won't burn the file.
Could someone please give me some guidance or what to look for to straighten this out.
. You will notice when you go to save there are a couple different .wav files you can save it as. Theres a windows PCM which i believe is what you are supposed to use then theres another one that won't work right when you burn to cd. I made this mistake once and it would burn my songs to cd but only the first few seconds of it. This might be your problem. I believe it will also tell you if you're saving it in the "other" .wav format that you are saving to a lossy type of compressed file.
