M
Muckelroy
Member
Sorry to bug you guys again, but rest assured I have done my homework, and have not found the answer to these questions so far. So here goes
My Otari MX5050 1/2" 8 track model number is not followed by a MKII, or MKIII in the model name, and I see NO identification on the machine that says MK-anything on it. So would that mean that it's a MKI? Anything corky about that? (All is says is MX5050.)
Also, i've noticed that the in's and outs of the machine each have a line level "Hi and Lo" level switch. So, does "HI" mean that it's accepting a balanced input level, or does HI mean that it's accepting an unbalanced +4dB level? And how about for the outs?
OK, and here's my last concern -- I intend to use a balanced patch bay setup. The unbalanced direct-outs of the M-308 will be normalled to the tape-inputs of the Otari via the patch bay. However, the inputs of the tape-ins are balanced.
So, if the patch bays, and the patch cables, and the cables running from the patch bay to everything else were all TRS (balanced,) would that cause a dropoff of signal level once the signal gets to the tape ins? If so, can that be fixed by the Hi-lo input level buttons?
(now bear with me.) I also would have the PGM outs running to the patch bay. The PGM outs (buss outs) are switchable from balanced to unbalanced. If I kept them switched to balanced, and sent the balanced PGM out to the balanced tape-in, would that level be significantly hotter than the direct-out unbalanced level, keeping all variables the same? Could it be matched back down if I switched the PGM outs to unbalanced?
ok, sorry for all the question marks. I'm just wondering what does what before I get all these cables. I'm not sure if I should use TS or TRS cables for the direct outs, or if that would make a difference in level consistency for the tape-ins.
-callie-
-callie-
), or try something else. What I'm wondering is, what could that something else be? If, for example, I used TRS cabling from the direct outs, all the way to tape-in, and shorted the tip and the ring leads, say, in the patch bay somewhere, would that even out the signal level and vamp it back up to "balanced" level? My only worry about doing that is that once it reaches the otari input, it will do like any other balanced circuit does, and flip the phasing of the tip and the ring, and cancel out the signal altogether. Would that happen if I shorted tip and ring, without using a bal-unbalanced output transformer?
