One of the worst situation ever...
  • Thread starter Thread starter oceanflame
If you lose all your data/songs/stuff,are you willing to pay in order to get it back?
  • I can't lose all this! I'll pay the price!
    Votes: 1 14.3%
  • I got my lesson I guess, so... no.
    Votes: 3 42.9%
  • It depends on the cost of all this...
    Votes: 3 42.9%
  • Total voters
    7
I narrowed it down to a faulty SATA drive (only a few months old!) Something got messed up somehow.
Is it me, or IDE hard drives seemed to be a lot more reliable than SATA? 'Cause I have another computer with an IDE hard drive, it has Internet, it went down a couple of times, I don't know how many power failure, etc... and it still works! And now the brand new PC with the faulty SATA (after only 1 year and 3 months) just died like that (no Internet, no power failure, always turned on and off properly, etc...).
If all else fails, stick it in a plastic bag and put it in the freezer overnight. That may get you several hours of time to get the data off the drive. This has saved my ass twice with drives that wouldn't spin up.
Hopefully you have learned your lesson, back up immediately after you saved something that you would be in a world of hurt to lose.
Ive lost two hard drives in a year...
Do I record others for money..no
Can I record everything again...yes
bought another external and a 1TB...back to work :)
That's probably my thought.
I like the idea of keeping my old data forever, but I don't like my old recordings, so I probably wouldn't mind losing them that much!
Last time my PC wouldn't boot, it turned out to just be the windows installation that was screwed. I bought myself a really cheap, really slow IDE drive, and installed windows onto it. That way I was able to boot up and found all my files to be intact. They were on a seperate partition to my windows install anyway. Shortly after that I bought another new hard drive exclusively for storing my audio stuff.
OK let me explain the "Freezer" trick....
There are several ways that a hard drive can fail. One is that the small arm that moves the read/write head over the platter fails - it becomes stuck or damaged. When this happens the symptom is that you will get a loud "clicking" noise coming from the drive, a.k.a. "The Click Of Death". The freezer trick works ONLY for this particular problem, so if you dont hear a click it will probably be a waste of time.
Odds are that when you hear this click, you are hosed. But SOMETIMES you can get the head start working again, briefly, through the freezer trick.
First, remove the drive from the computer. You will want to then set up a second computer, or install and set up a new boot drive in place of the old damaged one. You may only get a few minutes of functionality, and its likely your damaged drive wont boot anyway, so the idea is to just give yourself time to copy files you don't have backed up. You want a working drive in the system. Drives are cheap - 160 gig drive at my local store is $29.
After your system is working again, place the damaged drive in an anti-static bag and leave it in the freezer over night. As the metal freezes it contracts, which will move the head slightly. Then open the case for your computer and make sure you are ready to plug in your damaged drive as a data drive - if its an IDE drive, you want to be sure the jumpers are set properly. Finally when you are ready, take the damaged drive from the freezer and quickly install it. Turn on the PC and cross your fingers. Make sure you know exactly where your precious files are stored, because even if this trick works you will only have a few minutes before the drive heats up and fails again. Then if it works, start copying your files to the new drive.
I've tried this trick about 8 times (I do this sort of work for a living) and I have about a 50% success rate of getting SOMETHING off the drive. Usually you can only count on about 5-10 minutes of functionality. My best case brought the drive back for about an hour. I've never heard of this trick working more than once, so be advised.
Of course the best remedy is to always have three drives in your system - one internal system drive for booting the OS and holding your programs; one internal data drive for your files, pus a backup of your system drive (I use Ghost); and then finally an external USB / firewire / esata drive for data backup. You should do an incremental backup at least once a week, or after every major session. Do this and you wont need to be pulling hard drives out of your freezer.... :D Don't do it and: :spank:
