I set one to Master, run the midi cable "out" to the "in" of the slave machine. When I hit "play" on the master machine, the slave machine doesn't start. Any help out there?
JR's right. Set one to Master & the other to Slave.
Then make sure they're both on the same frame rate.
[I thought the M/S setting was obvious, so I glossed over it]./DA
Thanx JR.
I've never had the opportunity to sync two FD's, but I've synced the FD-4 to the Tascam 564, so I know it can be done.
Check your settings & keep trying.
FWIW, I like the Fostex FD's, and have considered getting another one. If one is good, then two must be better, eh?
That's my reasoning, anyway.
Thanks Dudes,
I'm 99.9% sure one is Master, the other Slave. What frame rate should it be set at? I'll re-check next time I'm at the machines. I'm busy with "life" right now, but thanks much for your help. I let you know what I find out- AND PROBABLY BEG FOR MORE HELP!
Also, does it matter whether I'm formatted at "Master" setting, or "Normal?"
