No sound out of my cubase...
  • Thread starter Thread starter AJ_Cantos
A
AJ_Cantos
It seems to be producing sound, but I can't hear it, so I think it would be a sound card problem, but, How to fix it?
Thanks...
Please provide more info as to cubase version, soundcard installed, keyboard connection ..............
I just installed Cubase SL last night and had the same issue. What solved it was twofold. First off I had to go into the device setup menu and change from the ASIO driver to the ASIO/Direct X driver. At that point I got audio. Then when I shut the program down and re-started it there were error messages about not finding my soundcard, and no audio would play. I went into the VST connections (I think, from memory) and had to manually select the soundcard and add the channels in the output tab. After that, all was fine.
Hope this helps.
Darryl.....
