I
isaiahmoon
Hello board--very informative and comprehensive site.
Let me preface by saying that I am new to my own recording, have recorded hundreds of hours in other studios but never at the helm myself.
I recently bought the EMU Tracker Pre audio interface to go with the new laptop with Vista 64. EMU came bundled with the Cubase and Cakewalk software--all in all a pretty good deal. Installation was no problems, everything has loaded correctly (or so it seems). I am running a bass or guitar through the inputs on the EMU interface, into the USB port, and then into either Cubase or Cakewalk. I do not run studio monitors yet, but the EMU interface is set up for direct monitoring, so I am using studio headphones via the direct monitoring jack.
I am getting levels in either program and when recording I can see the levels moving and the wavelength being created as I record. The problem is...I can't hear anything on playback. I have read the manuals and set up as they said, changed the drivers to the EMU ASIO drivers, and made sure that the input and output is selected to audio interface. I also checked to make sure that my computers playback was set to the EMU unit in the audio control panel. But I just don't get any sound on playback, or cannot hear the initial track if I try to record a second track. For that matter, I can't hear the click track in the headphones! I also made sure that the monitoring button in the software was turned OFF, since the EMu unit is set up for direct monitoring. So obviously, there is a break in the output somewhere.
Any ideas? I have read and re-read the manuals and checked forums. Others have had similar problems with no playback audio (which is how I've known to check the steps I have already gone through), but none of the fixes have worked. Is this a problem with the direct monitoring function of the EMU unit, or is it a software problem? Would lining out some studio monitors out of the EMU solve everything (I would have tried this already, except that I don't currently have any monitors. Perhaps after Christmas). Any insight would be much appreciated, as I can confidently say that I have little idea what I am doing.
JW
JW
