H
hobbsca
Until recently, I have been recording my husband's band with a cassette recorder. We moved to using my laptop due to the poor sound quality we experienced halfway though the longer 90 minute tapes we had been using to record a 45-60 minute set. The recordings are strictly a tool for practice, i.e., timing, missed lyrics, etc.
I have read quite a few posts regarding laptops, sound cards, and microphones, but I admit, a lot went over my head. So some may cringe as you read my questions.
First, the equipment & software:
Dell Latitude CPx PIII, 512 meg memory, w/stock ESS sound card.
Running XP Home with Goldwave 5.14
Speco MHL-1 Uni-Directional Dynamic Mic, dual high/low impedance (using the mic jack (not the in-line jack)).
Area recording in:
Not the greatest, but usually a bar (that's were most gigs are here in Houston)
Okay, now for the questions:
1. The recording I made last weekend wasn't bad, it picked up the vocals, lead guitar, and after finding the right place to set the microphone, the base guitar and bass drum. I wasn't able to capture the sounds of the cymbols or the high hats. Could this be due to the microphone I am using? Should I be using a different mic? I currently only use one mic to record the band and would like to capture high, mid and low ranges.
2. Each set was saved as a PCM signed, 16 bit stereo WAV file from Goldwave. The files sounded good the night we recorded. When I cut the sets into individual songs and saved them as Layer-3, 44100 Hz, 320 kbps, stereo the sounds became more mutted, not as crisp or clear. Is this typical for these file conversions?
Thank you.
Cecilia
Houston TX
Area recording in:
Thank you.
Cecilia
Houston TX
