Newbie Question about loops
  • Thread starter Thread starter Schehera
Schehera
I downloaded a wav file sample that is a vibraphone sound.
When I opened it in soundforge there was a section marked off toward then end of it as 'Sustained Loop '
What is this and how does it work ?
Thanks (:
Here's my basic definition for you. A "sustained loop" is a portion of a WAV file that loops to create sustain. For example, if you import that vibe file into a sampler you can press a key and it will sustain until you release the key.
As you can see the file you have is short, probably less than 3 or 4 seconds. But with a "sustained loop" you could virtually have it play for an hour just by holding a key.
Very basic, but hopefully will help you.
Stray
thanks stray
I will try this out - I'm having difficulty booting up my mpc at the moment -
stray411 said:
Here's my basic definition for you. A "sustained loop" is a portion of a WAV file that loops to create sustain.....
Very good answer, stray.
Re: thanks stray
Schehera said:
.....I'm having difficulty booting up my mpc at the moment -
What is the exact problem you are having?
spin
well...
The floppy drive doesn't read anymore - i need to invest in an external hard drive or zip drive - I'm kinda wary to buy anything off ebay for my mpc2000 - but maybe I should. ??? I do have paypal - lol
This akai is becoming more obsolete everyday.
also...
Is there a way i can tr yout that sustained loop in my comp ?
Just to hear it - mess around with it ?
Re: well...
You can pick up a used Zip drive for real cheap, compared to using floppies you will love it. Only thing is certain things (such as OS updates and *.pgm imports) have to be imported via floppy.
Here is pricing from MusicGoRound.com on Zip drives. I would never buy anything from Ebay, but these stores are great. They even offer a limited warranty.
IOMEGA 100MB ZIP W/AC Novi, MI $79.99
IOMEGA ZIP 100 Louisville, KY $39.99
IOMEGA ZIP DRIVE 100 Louisville, KY $59.99
I don't know about the MPC, but the S2000 uses the same floppy drives as Commodore Amigas, which are easy to find and wouldn't cost you more than $20.
Sure, but you'll need a VSTi or DXi sampler. This will work the exact same way I described for the MPC.
Good luck.
Stray
