New to recording (Two Songs, and a lot of questions)
  • Thread starter Thread starter Talus
T
Talus
Well the topic really says it all. I've only been doing this for a couple weeks now, but hopefully I'll manage to avoid asking anything too painfully stupid.
To get the ball rolling the gear I'm using is as follows:
Cubase 5 essential w/ Ezdrummer, Addictive Drummer & Trillian
Tascam US-122mkII interface (is this even any good? Not much info about it anywhere)
Sennheiser MD 421 & Shure SM58
Generally I've been micing my amps with the mic about an inch from the amp, with it pointed slightly above and to the side of the speaker cone, and have the input volume set a little ways below clipping point (I've read conflicting opinions on this however?). The amps are usually played at a loudish bedroom volume.
Now the songs. They can both be found at http://www.soundclick.com/Talus both are instrumental rock. Think the bluesy side of Satriani, without the insane shred. Anyway, both are still very rough. My playing is fairly sloppy in some places, and it may be the cause of some of the problems. If that's the case, say so. Any comments or criticism beyond what I'm asking is also greatly appreciated.
Trouble is the most recent song, and also the one that's got the most problems, so we'll start with that one.
The biggest problem with this one (ignoring some really sloppy playing) is that I've no idea how to mix it. I've double tracked just about all the guitars, but I'm having a lot of trouble mixing them without resorting to extreme panning, and constantly moving things around.
0.00-1:04 I started off with just the clean guitar, I double tracked it, one hard to the left and one hard to the right. At 0:32 the solo kicks in. At first I tried Having the solo dead center with the clean guitars off to the sides, but I didn't find that worked very well. I ended up moving one of the clean guitars 75% L and the solo 75% R, and it's an improvement, but still not that great. Can anyone suggest a better way of doing this?
1:12-1:52 Again, the first couple bars have the clean guitar panned hard left then hard right, but a few bars later when the distortion guitar kicks in, I ended up panning the distorted to one side and the clean to the other. This just feels sloppy and sounds kind of weird having the clean guitar jump from both sides to one.
This kind of trend continues throughout the entire song.
The song Chill turned out much better. I'm really happy with the how the acoustic guitar turned out in that one (although for some reason I just can't get that sound again).
My only real problem with this one was the lead tones. I'm fairly happy with the sound of the first solo, but the later solos are kind of odd. The solo at 2:14 is a slightly dirty amp, pushed by a Tubescreamer with the gain at 3/4, and the solo that directly follows it is an OCD at 3/4 and the tubescreamer at 1/2 yet both are recording much much cleaner than they actually sound. Anyone have any clues as to why this is happening? I've tried playing with a few mic positions, and I've also tried micing it in stereo, but it hasn't really helped.
Additional Questions:
1) Is there a way to get a printed version of the Cubase documentation? I'm not sure why, but I've always had a hell of a time trying to read anything on the computer that's more than a few pages long.
2) can anyone reccommend good books on Cubase, mixing, or recording in general?
3) Is there a trick to recording clean guitar? I'm getting a lot of spikes and dips in my sound, and a lot of the time it feels like I really have to dig in to the guitar to get any kind of sustained sound. Adding compression in Cubase seems to help a tiny bit, but the recorded sound still decays much faster than the amp that I'm recording does.
4) Does Cubase have the ability to change pan, EQ, Inserts part way through a track, or do I have to create another track?
Well, you've got a whole heck of a lot of questions here. I'm just gonna take a look at a couple.
Leave the solo guitar in the center. It's the main focus of your song and it deserves center stage. I don't think you should be re-panning anything except as special effects. Find the instruments' space on the stage and leave them there. I think you should leave your clean guitars panned out to the sides or nearly to the sides and the solo, bass, kick and snare in the center. I'm curious why you thought it didn't work that way. It might be an EQ thing where one track is stepping on another in the same space and eq range.
Yes, Hit the "W" button in the track you want to adjust then make your changes, adjustments, etc as the song is playing in Cubase. Whatever changes you make in that will be recorded into the Automation track.
Hey Talus,
Welcome to the recording world. Get prepared to part with blood, sweat, tears and mostly cash. I'm just kidding, I hardly bleed anymore.
Well I'm listeing to your songs as I type and my first thought is Newbie my ass! LOL. They sound excellent and I really love your style.
I really don't have a lt of suggestions for you. You have done a great job and it will get better with every track, mix, and recording.
A couple of points. You mentioned that the miced sound isn't reproducing as well as you like. Welcome to "should I get a better mic, preamp, both?" Mic is another rung in the signal chain so what you hear isn't the same as what the mic hears (or actually reproduces to put it better). I have found that it's a trial and error thing and I sometimes find that to get the recorded sound I want, the live sound I'm hearing can be quite different, generally exagerated because ears are still better than any mic/interface/DAC/amp/monitors.....
I ended up going the modeling route with amp sims. It was just easier for me and the sims are getting so good. I can sound like I have a Les Paul into a 1959 Marshall stack miced with vintage mics, tons of effects, yada yada yada.
I spend a lot of time with VST's. EQ's, compresors, exciters, you name it, I've at least tried the demo. It's a way to improve the signal chain with less than perfect gear!
Not much advice, but you are definately headed in the right direction. Good Luck!
I have nothing to say that's of any help whatsoever. But I think both songs are neat ! I like 'em. I wasn't thrilled with some of the snare sound on "Trouble", but that's more about me than the drums. I was pleasantly surprized by the sound of EZ drummer, however.
I agree the panning going on in trouble is strange, it kinda confuses my ears for some reason. over all I think they are pretty solid recordings. I really like your guitar tone on the solos, it fits very well.
After reading your questions I'd guess that the advice that you'd get from many pros has to do with properly equalizing the tracks you have to get the desired effect from each. Sadly, I am not qualified to tell you exactly how to do that. But, I've seen that come up repeatedly in some of the "permanent" advice threads.
