Mic Placement In Room
Well, The room is about 20 feet long, 15 feet wide, half the ceiling is about 18 feet, the other half 9 feet high. I am facing a wall in one of the corners in the high ceiling area with my back to the other lower ceiling area. There is no sound treatment at all (I wish I had my own room and space, but that isn't happening). I can hardly ever find time to record without noise around, this was one of those times. I have the gain on the mic set high enough that I get a good signal, but low enough that it doesn't pick up too much room noise, so it seems to work out. The problem I am having is that it almost distorts when I sing the louder parts, so I have to pull away off to one angle when I sing those parts, so I am trying to get that under control. I am trying to keep the signal chain as simple as possible.
Ya Timothy, this time I decided to plug in to see how the noise level was affected. It is alot quieter than the Peluso CEMC6 mic I guess, but I have to test that some more. I do like the mic sound more, so I will have to get used to it until time to upgrade, but I am pretty satisfied.
Also, I noticed a big improvement when I added Mid-level EQ when I played back on another PC. So I aggreee that some EQ will be necessary. The AT 4033 is nice, but doesn't sound as full and robust as I would like, thanks for the commnets.
