Nice - My bass player (who also plays guitar) bought a JVM210 and I play it almost weekly when we get together. Even the 210 has a myriad of sounds but we usually stick to 2 or 3. And the line out is great (not at all like the fizzy shit out of my 900), a little bassy compared to using a 57 but he's a bass player so he loves it haha...
Yeah the line out on the JVM is a speaker emulated line out, which is suitable for going straight into an interface. I agree it sounds bass heavy, but it's okay. The line out on your 900 (and mine) is just straight pre-amp line out and is meant for live use going straight into the board. The other says "recording" but it's useless unless you use a speaker cab simulator, and even then it's crap.
But back to the JVM, I did my first mod on this thing today. I did the "negative feedback" mod. I don't know the exact inner workings, but this is how I understand it in a very paraphrased generic layman's nutshell. Someone else please chime in with better details or to correct whatever I get wrong. Caution, long post ahead:
The JVM, like most amps on the planet, uses negative feedback (not the squeal kind of feedback) to keep the power section sounding clean and tidy. The power section is kept tight by re-introducing the signal and certain frequencies and noise gets cancelled out. The stock resistance in the feedback circuit is relatively low, so that makes it hard for the power tubes to crunch up and add that rich juicy power tube saturation even at really high volumes. Eventually when the volume is loud enough the feedback circuit collapses and lets the signal through unfiltered, and that's when the goodness happens, but in stock form it's more like an on/off and it has to be really super loud. That's where this mod comes in. The JVM is basically a super hot-rodded JCM 800. What made the JMP and JCM800s such monstrosities is that they supposedly had the least amount of negative feedback of any of the classic Marshalls and the power tubes got involved very fast and with a very natural and linear type feel. So what this mod does is reduce the amount of negative feedback in the JVM and let's the power tubes get involved sooner and more smoothly. The result is a really rich, harmonic overdrive that crunches up with less preamp gain yielding a thicker, more full-bodied sound, and the amp is more responsive to pick attack. Pick lightly, it stays cleaner, hit it hard and it goes berserk. Overall having the negative feedback reduced makes the amp a little louder and more open/dynamic sounding.
All that was involved is snipping a wire in the feedback circuit and soldering in an adjustable pot. I used a 1 meg audio taper pot, which keeps it stock at 0, turn it up to about 3 and you get into EVH modded Plexi range, and around 5 is full JCM 800 style openness. After that you get into even less negative feedback wide open "Vox" style ranges. The difference is considerably noticeable as you turn the knob. Marshall should have this option come stock on these mega amps. It's so easy and sounds so good. I can't possibly understand why they wouldn't include something like this. The amp already has 2000 knobs on it, what's one more? Anyway, it works great and sounds in-fucking-credible!
Here's a couple action shots:
Marking tubes so they go back in in the same spots
The guts
This is the heart of the negative feedback circuit. R58 is the resistor. One method involves snipping it out and replacing it. No way I'm doing that, so I used a different method I found online, and followed the blue wires of that connector...:
Here's the other end of those blue wires connected to the speaker out board:
This is the wire that will be snipped:
Here goes nothing....
Checking the pot. Pot on 0 - this will give stock JVM negative feedback
JCM 800 range pot value about halfway. The stock resistor will provide the rest.
Pot at max - this will yield the least amount of negative feedback
Wires to pot soldered in
Wires tucked away and zip tied back into place
Attached to pot
Doing a successful mocked-up test run. I'm gonna get a better pot and a Marshall knob before I drill the chassis and mount it. I don't want to drill the front of the amp, so it will go on the back. There's a really nice open spot near the power chord for a knob.
And that's it! A little nerve-wracking, but very easy overall. This badass amp just got badasser!
