Hello all,
I did a search of the forum and did not find an answer that fit my problem.
I moved into a new house that has a great space for a jam room. Currently I have it set up with an electronic drum kit, 2 1/2 stack guitar amps, and a somewhat all purpose old Fender amp that I run the drums, bass, and vocals through. Obviously this is not a great solution. The "drum/vocal" amp is ok, but not what I would like. Also, the guitar amps are way over powered for the space and it is difficult to get a decent balance.
My intended solution is to get a mixing board, power amp, and a couple of PA speakers. I have guitar modeling floor pedals that I can run my guitars through, a bass modeling pedal for the same, and of course I can push my drums and vocals direct from the mixer.
What I am hoping for is if someone here has some experience with a good all purpose mixer. I would need no more than 10 channels and probably not use more than 8. I have reviewed the Yamaha mixers that have built in effects, but I really don't need them as I already have an outboard effects rack with reverb, delay, and EQ. This would be all I need for the vocals. The guitar/bass pedals handle their own effects.
Also, I have reviewed quite a bit of power amps and speakers, but I am unsure what output I would need. A 50watt 1/2 stack guitar amp is more than enough by itself, but I have read that PA amps aren't necessarily similar to individual instrument amps when it comes to power ratings.
The space I am using is approximately 15' x 20' x 8'ceiling. I don't wish to over power the room mainly due to the cost of equipment goes up in relation to power rating. In general anyways.
Budget is always a concern, but I am selling all of my amps which should fetch about $1,100. Also, I do currently run and would like to continue floor monitors for the drummer. So any power amp I get would need outs for this or the speakers would need to have outs to monitors.
Does anyone have experience in setting up something similar and what equipment would work?
Thanks.
Thanks.
