New Amp Day!
  • Thread starter Thread starter MatchBookNotes
yeah, there is one. its a little bit smaller than a redbull can. What is the accessory plug for?
And i should definitely plug the amp into a surge protector, shouldn't i?
If you are talking about the AC plug somewhere on the amp, is can be used to plug in anything.
A surge protector a a good idea anytime.
I e-mailed traynor to see if there were any things the factory said but all i got in response was get a new three pronged plug in chord.
Any idea how much that will run me?
well this one is like a fender. The chord runs up into the amp and i'm not yanking it out... at least not without proper instruction. haha
ok wiring this thing should be easy... you should be looking at 3 wires... black white and green... right??? well the black goes to the primary of the transformer and is the "hot" it will be wired through the fuse ... the white is called the neutral and is your primary ground and also goes to the primary of the tranny but will mostlikely NOT go through any extra wiring... just to the tranny... the green is called the ground and/or safety... it's purpose is to give an extra path to ground in emergencies... and it is tied to the chassis... anywhere you can get a good convenient connection... though i generally try to tie it close to the ground for the supply filters personnaly...
hey guys, do any of you know any place that's good for hosting MP3s that isn't myspace? I want to post some recordings i'll be making with my amp tomorrow.
