Thanks guys,
I went with the Sony. I got it running now and it seems to work great.
The worst install I've had in a long time though.
Things to know:
1) Adaptec's EZ CD Creator likes to work alone. To get it to work with other burning apps is difficult at times...especially Sony's CD Extreme! (which isn't even worth installing)
2) When you uninstall EZ CD Creator, it does NOT fully uninstall. It leaves pointers in the registry that can over-ride cdrom.sys and can leave your system cdrom-less.
HKeyLocalMachine\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFCl-087002B El0318}
Delete keys "UpperFilters" and "LowerFilters" and restart. Yippee!
Even if you've uninstalled EZ CD Creator, you're still using its alternate driver...which you won't care about perhaps until you try to install other burning software!
3) If you ever install adaptec's ez cd creator on Windows 2000, both versions 3.5x and 4.0xx, be sure to download ALL of the updates from Adaptec. Then install the software as follows:
a. Run the install from the CD.
b. When it asks you to reboot, DO NOT REBOOT.
c. Run the patch(es). There will be two patches to 3.5 and as of now there is just one patch to 4.02.
d. Reboot.
If you don't do things in that order you risk your machine NOT being able to restart. If your machine doesn't restart, BTW, boot in safe mode and uninstall ez cd creator and if necessary perform the registry hack above.
Welp, I just figured I'd write this down in at least one place, because I'll certainly forget 90% of it by next week.
Slackmaster 2000
