leddy
I would like to get out of the box for some EQ and compression needs. My thought is to mix in Cubase (I have SE), then send the 2-Buss out to some hardware (I'm thinking of starting with something like an Avalon 747 to have a Class A, tube comp, as well as some ability to high and low shelf EQ). I really only record jazz, so sonically, the tube comp seems like a decent direction.
Rather than rip the file to a stereo track in Cubase, I though it would be nice to get a control surface and be able to ride individual faders while I'm mixing down through the outboard gear and record it into Wavelab.
At the moment, my soundcard is a Delta 44. I don't record with it; I use an HD24 and dump the files into Cubase. The Delta is really only to get out to my monitors.
-Is it possible to configure the Delta 44 to send the 2-buss out on 1/2 and 3/4 at the same time? I need to monitor while I'm mixing down, obviously. I don't want to add a mixer if possible. I also need to get the signal back in the inputs at the same time.
-Is there a better soundcard that can handle this and sound better?
-Would the output from the 747 require additional gain (like having to go through a preamp) to go back into the soundcard?
Sorry if these are noobish - I've been an ITB guy - I need to get some of the basics of being hybrid. I think I'm ready since plug ins (even good ones) just don't give me what I hear in my head.
Thanks very much.
Thanks very much.
