satnomb
I want to connect my m-216 board a different way that I did, but I have a few problems. I was using my board in a very simple manner: keyboard in input tracks, and the main output to my digital multitrack wich have only 2 inputs.
I just bought a Korg Oasys pci card and I want to use it as a synth but also as an effect box. I don't have the manual of the mixer so it's not easy to me to figure how.
The RCA PGM out look like they are stereo? Is that possible? These PGM route the 4 subgroups which are mono? I want to route the output 1-2 to the multitrack but i'm not shure how to plug the thing. Also i want to dedicate one analogue output and one analogue input of the oasys card to the effect. Where the output goes (effect return?) and where the input goes (Output effect?). Again, I'm not shure how to do it.
Finally, what is the sub in? I try to hook the output of my multitrack there but I experienced some feedback.
Thanks for any advice.
Bernard
Bernard
). You see, the pan and assign buttons have different number-combinations on them. For example, the combination 1-2 and 1-3 will send only to bus number 1. This way, you can route your signals to one of the pgm outputs that you want, e.g., 1, 2, 3 or 4. The pans of the pgm bus are different; they affect how the signal is sent from there to the main stereo bus.
: How should I open the 216 for dusting the internals? From those 6 screws on the top or by taking the bottom plate off first? P.S. I'll give you the answer to this in 2 weeks if no-one else answers.
