Ujn Hunter
I don't typically like this type of music. However this song sounds good. I prefer the @HumanPlanet fix ov the original mix. The super high end sizzle that was tamed makes it easier to listen to for my ears.
Thanks, glad you like it! It's one of the weaker songs off the album.I don't typically like this type of music. However this song sounds good. I prefer the @HumanPlanet fix ov the original mix. The super high end sizzle that was tamed makes it easier to listen to for my ears.
I guess they are, but they don't really change the sound too much. I barely have them on. I was only using them to try and suppress the harsh highs. I thought you meant it was tuned.Are the tape emulation, de-essers and stuff not effects? I figured that was what you'd used on the voice?
As far as I know, tape emulation plugs add distortion. Whatever that means. If you are feeling there is harshness with the vocal, then take those back or out and see what results.I guess they are, but they don't really change the sound too much. I barely have them on. I was only using them to try and suppress the harsh highs. I thought you meant it was tuned.
From what I've read it's supposed to reduce the top frequencies that cause harshness since tape gives more of an analog sound. I added it months ago when the problem was already present without it.As far as I know, tape emulation plugs add distortion. Whatever that means. If you are feeling there is harshness with the vocal, then take those back or out and see what results.
Funny thing I have learned over the years, is that less is more....
Thanks, but I can't make alterations to the beat due to the producer dying years ago. Is there a way to fix any of that with just the mixdown?A little late to the party, but I gave this one a listen. For a genre that I don't typically listen to, it was actually pretty good.
One think that I would drop back is the snare. It seems to be much too "snappy". They sound too forward in the mix, and they sound mechanical. There's no variation in the attack or volume which you would get with a real drummer. I would roll off the highs on them and if needed, drop the level a dB or 2.
Overall, I liked HumanPlanet's adjustment for the rest of the mix. It gave it more body without getting boomy.
I made some tweaks like you suggested. Is this better? I think it is, but I might need to rest my ears a few days before I attempt to fix the rest of the tracks.
Thanks for liking the song. I try and make things I don't see others doing. I also don't curse like normal rappers.It just sounds a bit bright to me. Nothing too crazy that couldn't be fixed with some EQ on individual tracks and maybe some massaging on the master bus. A quirky song, a pretty good song. Is it multi-tracked? You can't alter/change the beat?
