jrhoden
...And Justice For All
this is how im set up at the moment...
esp into ts9 out from ts9 to boogie...out from boogie to marshall 4x12.
i have my dod eq g-major and bbe sonic maximizer run thru boogie fx loop
what i want to do is build a switchbox with 4 or so switches so i can switch between the 3 boogie channels and choosing which of the 3 fx ( dod eq , the gmajor and the bbe sonic maximizer) to use with the 3 boogie channels
with the fx thru the boogie fx loop as soon as i turn the first one off it kills the loop...which means i have to
i was thinking maybe keep the eq thru the boogie fx channel and have a 3 switch box for the bbe and the g-major...
should i put the switchbox between the output from the boogie and the input to the 4x12 or what about hooking the bbe and the gmajor to the switchbox and running it thru the fx loop?
the first thing is thought the best way to go about building the switchbox....say 1 input from either fx send or from output of boogie with the 3 or 4 i/o loops for the fx then a single output ...
the reason i ask that is id like along with the 3 or 4 fx loops in it when all are clicked off theres still a dry signal going thru the box....
thanks in advance for the help and decoding this wall of text lol
