Name the best soundcards you know of
  • Thread starter Thread starter c9-2001
Echo Mona...
Echo Mona...
Echo Mona...
Echo Mona...
This is what I use now and it absolutely rocks. Check the specs and drool. It has 4 analogue inputs (with vu meters and good preamps) on the front pannel that I can plug any mic or guitar into. Has spdif and adat in and out. I partner this with an alessis adat ai3 for an extra 8 channels. That makes 12 channels in, more than enough for anyone.
Four high quality mic preamps with phantom power(+48v)
Four universal analog inputs with precision 24-bit 128x oversampling analog-to-digital converters
Six analog outputs (both XLR & RCA) with high-performance 24-bit 128x oversampling digital-to-analog converters
S/PDIF digital I/O with up to 24-bit resolution
ADAT optical digital I/O
Trim control and level meter for each input
Headphone output with volume control
Frequency Response: 10Hz - 22kHz, ±0.25dB
Dynamic Range of 110dB (A-weighted) on inputs, 115dB on outputs
THD+n: .001%, 20Hz - 22kHz
Nominal Input Level: +4dBu
Maximum Input Level: +22dBu
Microphone Input Level (balanced XLR):
EIN: -129dBV
Input Impedance: 1.5K
Gain Adjustment: 20 - 60 dB
Line Input (balanced TRS):
Input Impedance: 10K
Gain Adjustment: 0 - 40 dB
Guitar Input (unbalanced ¼"):
Input Impedance: 107K
Gain Adjustment: 10 - 50 dB
Analog Outputs (x6):
Dynamic Range: 115dB A-weighted
THD+N: .002%, 20Hz - 22kHz
+4 dBu Outputs (differentially balanced XLR):
Nominal Output Level: +4dBu
Maximum Output Level: +22dBu
-10 dBV Outputs (RCA):
Nominal Output Level: -10dBV
Maximum Output Level: +8dBV
ok.
Just an example of what I achieved with it,,,,,,,,,,,,
