wheelema
Boner-obo
I had a co-worker who posted (in a highly visible location) a Far Side cartoon where a boy is raising his hand in class and asking "Please Teacher, can I go home? My head is full." She had replaced 'Teacher' with the name of our Director.
I think I know how she felt.
Yamaha has recently released the 01X. Physically it looks like a mixer and indeed it is a digital mixer. It is also a control surface using the Mackie/Logic control protocol. It is a soundcard providing up to 24bit/96Khz A/D conversion. It uses mLAN (a superset of Firewire) to communicate with a DAW (the DAW is not a mLAN device so it ignores the mLAN data). Any mLAN components that you connect to the 01X are automatically recognized and configured, no DAW required (e.g., Kurzweil KSP8 w/mLAN card installed). It has eight balanced analog inputs, all with preamps, two of which are XLR inputs with phantom power, one a selectable Hi-Z. The preamps are alleged to be very clean, improved versions of the preamps used in Yamaha's top-of-the-line digital mixer. In addition to the mLAN and analog inputs, you can also plug in MIDI, and S/PDIF.
The 01X provides Steinberg VST Instruments effects (Vocal Rack, FinalMaster, and Pitch Fix) regardless of whether or not it is connected to a DAW.
Vocal Rack provides
Just when I thought I had all my ducks in a row, Yamaha rolls this thing down the aisle.
Ouch!
Vocal Rack provides
- a compressor
- a harmonic enhancer
- a 3-band equalizer
- a deesser
- a noise gate
- adjusts the pitch/tuning for “out of key” vocal tracks
- and pitch correction and tuning adjustments can be played from any MIDI keyboard connected to your computer
- Multi part or choral backing vocals can be created from a lead vocal source
- Fully programmable mastering effect plug-in
- Multi-band Compressor / Limiter
- 15 presets for all types of mastering applications.
- 20 presets for a wide variety of musical genres.
- Custom developed soft clipping models prevent excessive peak signals after the mastering process.
- Link switch for dynamics balancing
- Independent control over all compressor parameters for each band.
Ouch!
