MXL R144 noob question
  • Thread starter Thread starter habanero
H
habanero
Whats up yall.
I have recently put together an entry level home recording package, and the only part I wasnt really solid on was selecting the vocal / instrument mic.
After doing as much research as I could, and reading reviews, I settled on the MXL R144 Ribbon mic. At $87 bucks (with coupon) I thought it would be a great way to get started for now.
I am plugging it directly into my Tascam US-600, and I am using Sonar 8.5 pro. I have heard others say that this mic (as with many ribbon mic's) need a lot of gain. I started with the gain all the way down, and quickly realized that I have to turn it to about 95% to get the audio levels in the proper range. This is even singing about 4 inches away from the mic. Any further than that, and its too quiet.
I want to use this to record vocals, as well as vocals with acoustic guitar (sometimes at the same time). I was thinking I could sit about 2 feet away from the mic, sing, and play acoustic guitar, but that isnt going to work with my current setup.
So I guess I need to get a preamp to do this, right? Can I expect this mic with a preamp to pickup vocals and acoustic guitar from 2 feet away? I see plenty of youtube videos where people are doing this (not necessarily with this mic) and I just expected that most vocal / instrument mics would do this.
If a preamp would get the job done, should I go with a solid state, or tube? I am looking to keep the natural sound from the source, so I am thinking solid state. Would a tube preamp change the sound much?
Finally, how much dB boost should I be looking to add to this mic to get it to do what I want it to? I see some things max out at 20dB, while others go as high as 70dB. Is there a level that will damage the microphone? Is there a level that will make the mic useless due to clipping by adding dB's?
I am trying to stay under the cost of the mic if I am going to get a preamp. Otherwise, I would consider taking it back, and trying another option.
rather than spending a LOT on a ribbon preamp, consider adding a booster on the mic.
for $100 you can get 20db of clean gain to take the stress off the preamp in your interface.
Triton Audio Fethead
How much would something like that add to the signal strength of the microphone?
Uh.... 20dB.
Personally, I would take the ribbon back and get a condensor. Add the amount that you would have spent on a sub-$100 pre and you'll get a somewhat decent first condensor.
J
Replies
9
Views
759
TalismanRich
TalismanRich
CoolCat
Replies
24
Views
3K
Monkey Allen
Monkey Allen
Wabatuckian
Replies
9
Views
646
Wabatuckian
Wabatuckian
