SiGGY
Odds are you know what this is already but here's some info from me and manufacturer.
$425. I will accept best reasonable $$ offer.
I'd really prefer local buyers... however if it comes down to it...
Buyer pays shipping fully insured and packed by shipping store. I believe I still have the original box for board and PSU. So that might help drop costs a bit.
Eurodesk MX9000 /w rack mount power supply
24 channel board with 24 channel meter bridge; see pics.
Direct line outs per channel
Kept in a non-smoking air conditioned studio.
Board is in great working condition. I used it up until I replaced it with a larger board a month or so ago.
Issues:
Meter bridge for channel 7, and right channel of 3rd bus group (channel 6) are both inaccurate by 5-8 dB.
Specs...
* 24 additional Mix-B input channels, all with individual 2-band EQ, Level, Pan and Mute
* Dedicated 4-band EQ with 2 semi-parametric Mid bands offering an extremely wide-swept range from 50 Hz to 20 kHz
* Up to 6 Aux send busses, all switchable pre/post fader
* 6 stereo Aux returns with multiple routing options
* 8 subgroups simultaneously feed 16 multitrack outputs
* Built-in meterbridge with meters for each channel, subgroup and Main mix, monitoring either the channel or Tape return signal
* +15 dB gain available on all Aux sends and returns
* Highest-quality, discrete-balanced Mic preamps with -20 dB pad, Low-cut and 48 V phantom power
* Balanced Tape inputs/outputs, switchable for -10 dBV or +4 dBu operation
* Channel, Group and Main mix insert points
* 100 mm high-precision logarithmic, tapered faders with big console performance
* Separate solo-in-place and PFL busses available
* 2-track tape monitoring with multiple routing options
* 2 separate headphone mixes and Talkback facility with built-in microphone
* State-of-the-art op-amps for crystal clear audio performance
* BNC connectors for 12 V gooseneck lights
* Expander port providing universal 1/4'' link facilities to any other console
* 400-Watt, external 19'' power supply with superior transient response
Issues:
Specs...
