Munches Tune Room.
  • Thread starter Thread starter CMunch
CMunch
CMunch
Crude sketch of the room I have to use,just about finished but will hafta use it as is for now.:)
Rockwool has been fitted to floors,partitions and coombs and Kinspan to outside walls,
Only going to be using it for guitar and maybe some vocals depending on how much I suck.Have two desks in there,one pc rigged up for recording and the other for general use.
Looking mainly for advice on layout any further treatment acoustically I shoud do to the room,will the coombed section have an impact on my recordings?whatever you think I need ta know.
Using usb interfaces,Fostex monitors,SM57,some pics of the gear I`ll be using,kinda piled into the room on my albums.Cheers
Yo MunchDude! :D
Hopefully Rick or Ethan or other knowledgeable fellows :p will pop in here for ya but I think if it were my room, I'd start with the computer at the wall with the window (kinda like where it is now :p) cuz of the door on the other end but I'm wondering how that window will mess with your mixing as well as the sloped ceiling. ? You keepin it? (the window)
Not sure but....
What I was thinkin was to buy (or build) your bass traps (broadband) and start with the 4 1/2 corner and put a 4 footer there, and trap the other corner across from it. Floor to ceiling. Have a decent sized gobo right behind where your monitors will be, extending a little below and a little farther out from where your monitors will be. Kinda like a big patch of stuff on the wall behind the speaks.
Can you bring the desk out into the room very much without losing too much jam space? I think optimum mixing is a little over a third of the way into the room. I don't have room for that but getting the monitors off the wall will give em room to breathe.
Bass trap the corners behind you (sitting at the desk) at the wall corners... and where the wall meets the ceiling (where possible).
That's about all I got dude. Wish I was a little more savvy with this stuff. I know that bass traps are your friend especially in smaller rooms.
Hey...once ya get goin on this, post some progress pics, huh?
Peace dOOd....Kel
This is what I'd do. Forget the long axis monitoring axiom and go for symetry.
I don't have time to finish this now but I'll be back with the rear wall later.:) Think "polycylindrical diffuser" with patchwork absorption and superchunks.:D
fitZ
Oh, what the hell, here it is. Sketchup makes it quick and easy, down and dirty.:D
Awesome dude,thanka ya much,I take it the foam I`m lookin for is about 100mm thick, It`s gonna be tuff finding a contract at work that needs it,funny feeling I`ll manage though.;)
The curved panel on the back wall,is that something I can construct myself,like outta finished ply? if so would it need filled with anything?
Sorry dude,zero knowledge of this stuff.
Rick...most excellent! Much better than what I was thinkin. :o
Nicely done, sir. ;)
Your welcome.:)
Yes, Well, however these panels can(and should be) made of fabric wrapped RIGID FIBERGLASS such as Owens Corning 703, or equivilent. The thickness is actually 4" for those who aren't familear with metric dimensions. I know rigid fiberglass is probably very difficult to find in Scotland, especially 100mm thick. But you COULD build wood frames and stuff them with 100mm 3lb density ROCKWOOL or equivilent. I highly doubt you could find 2'x4' panels of the CORRECT foam and density, especially in Scotland, but I may be wrong. If you could, this would be the simplest to impliment, as all you would have to do is cut it. However, the rigid fiberglass and mineral wool type products work better.
There are many ways to do this stuff. It all depends on your construction skills, tools, material availability, and most of all... imagination. The angled corner diagonals would be the most difficult to impliment, simply because of the intersecting angles...at least to make it look appealing and work correctly. If placing them diagonally across these angled corners is too difficult for you, you could place them flat against the wall, but it won't work as well for bass trapping.
I can draw up a set of alternative construction ideas for ROCKWOOL type framing as Rockwool etc is difficult to simply wrap with fabric, as it is a limp mass product and isn't rigid like the fiberglass products. Again though, I'd have to know your skill/tool level to design them. I am very adept at construction as I've been a journeyman millworker/cabinet maker for 30 yrs, so this stuff is easy for me. But I have a shop too, which makes things like this easy to build as well as design. Remember too, there are hanging issues, and backing issues and fabric wrapping issues, that all have to be thought out in advance to make this stuff come out the way I envision it. I really don't have time at the moment to go into all the little details that must be addressed when building these sort of things. And the designs actually depend on what sort of ABSORPTION materials you have abailable and can afford. So let me know what you can get there and we;ll work from there.
Yes and yes.:D The simplist way to make these is to fasten two cleats as show(there are other ways as well, which I'll show later)with wall anchors and then insert one edge of 1/4" ply sheet under the lip of one anchor and bend it till you can insert the other edge under the lip of the opposite cleat. Then stuff regular batt insulation into the void, although there is an alternative to make it easier, but more expensive. I'll show that later as well. You want to center this on the rear wall. Also the width dimension between the cleats is important to get the right curve(not a perfect circle, its actually an elipse) with a panel thats 48"wide(I made this 72" long btw)
Well, isn't that why you came here?:D Voila! Answers.;)
BTW, the array of square absorption panels on the rear wall are intentional because of this known fact. If you have say a 4'x8' panel of absorption material on a wall, it will absorb X Sabins of sound( ONE Sabin of absorption is equal to the absorption of a 12"x12" OPEN WINDOW). However, if you cut this panel into, say, 12"x12" patches, and arrange them in a patchwork array, the will absorb as a WHOLE, more than the panel in one piece. This is because of a known phenomena called the EDGE EFFECT, whereby DIFFRACTION at the edges contribute to the absorption of the patchwork as a whole. Not only that, but because of the areas of absorption having a flat wall boundary in between, another phenomena takes place called "impedence difference"(simple explanation) whereby reflection and absorption take place...which in effect allows DIFFUSION somewhat to occur. Don't ask me for details...this is a much simplified explanation...suffice to say, thats the reason for the patchwork design. The poly helps "scatter" the sound, which is not really diffusion...but it is a simple way to reflect sound at angles from a close proximity rear wall. However, this only helps with mid and high frequencies. Low frequencies in a SMALL room are a bitch to absorb. Hence the use of panels applied diagonally across the corners as Low frequency modes terminate and reflect out of the corner intersections. ALL OF THEM.
What I had NOT shown YET, is diagonal panels applied across the rear wall/ceiling intersections and the side wall/ceiling intersections. I didn't have time for that and still don't. In fact, I have to leave now. But I'll be back.
fitZ
btw, heres a picture of one of the frames I made for fabric covering my sidewall/ceiling "superchunk" absorbers, and a jpg of how they look in sketchup and a jpg of a model of my control room absorption scheme jsut to give you an idea of what you can do if you have the skills, tools, and imagination.;)
is.php
is.php
is.php
is.php
Thanks again dude, as luck would have it I`m a carpenter so making the panels etc. is not a problem:)
Would 4" thick insulated boards coated with GRP then fabric work,or would it need to be the full thickness in fibreglass? like you say I doubt here I could obtain that thickness in fibreglass alone.
Cheers.
