B
bloodsample
Hi,
First time post, hope this is the right place..
I have a basic PC recording setup but as it currently stands, I'm not able to overdub recordings. What I mean is that if I, for example, record an acoustic guitar track and then want to add vocals while listening to the recorded guitar, everything gets recorded in the new track (both vocals AND guitar). I want to have the vocals be in their own distinct track without the previous stuff played over it every time.
I hope that was clear enough.
Ok so I thought of an easy fix to this, but it seems a bit superfluous, let me know if I'm way off here.
Gear chain:
MICS --> UB1202FX (small mixer) <--> Audiophile2496 (audio interface)
The connection between the mixer and the audio interface is via the Tape IN/OUT of the mixer (RCA cables, both IN and OUT on the audio interface)
While I record, I monitor everything with headphones plugged into the headphone OUT of the mixer.
The trouble is that when I select the TAPE IN (coming back from the PC) on the mixer to not go into the mix, I can't hear it on the headphones. But if I do enable it, then it is recorded along with everything else (which is exactly what I'm trying to avoid here). Now on the mixer I can send the TAPE IN to the control OUT but then only the TAPE IN goes to the control OUT and I can't monitor the actual mic inputs of the mixer (ie I can't hear what's coming into the microphones as I record). I found a cheap fix where I merge the control and headphone outputs with a Y-adapter, but then I only get a signal in the left side of the headphones (not practical).
Another solution I thought of is to buy another small 4 channel mixer (50$) to use only for merging the two signals to the headphones. So I'd run the output of the PC into the input of this new mixer as well as the outputs of the old mixer into the new mixer and run the output to my headphones. Is this the way it's supposed to be done?
How are people able to hear both the pre-recorded tracks and monitor the inputs of the mixer at the same time while only recording the mixer inputs to a track (and not the pre-recorded stuff) using headphones? I'm guessing people must use headphones otherwise you'd just get bleeding into the mics. I don't have a separate control room, this is a very basic setup and everything is in one room, I guess that's part of the problem.
I hope that wasn't too confusing.
Thanks in advance for the help.
Gear chain:
Yo A-Positive:
