Multi-carding Delta 66s using ASIO
  • Thread starter Thread starter nessup
N
nessup
Hey. I have two Delta 66s that show up fine in the M-Audio control panel, and I'm sure that audio is getting to each individual interface just fine. As for Ableton, I made sure as to enable channels 1-8 on the input config for the main m-audio asio driver. Channels 1-4 work just fine (which is associated with the first D66); however, channels 5-8 are always quiet (those associated with the second D66). Any idea what might be causing this?
--Dany.
EDIT: Just so it is clear, channels 1-4 receive audio into Ableton perfectly as I would expect it to, whereas when I physically send audio into channels 5-8, nothing shows up in Ableton, despite the fact that it shows up in the M-Audio control panel mixer.
--Dany.
Just checkin but make sure the inputs in the Delta Control Panel are not muted. On my screen I have to scroll over to the right to see those inputs. I use a single Delta 1010LT card.
I have had to delete and reinstall the drivers for my Delta 1010LT a few times and that is something you could try.
Although it doesn't help you in Ableton, I was wondering if those inputs showed up in another app like Cubase.
On the hardware settings of the Delta Control Panel there's some settings for clock synchronization, you could try and change those (I'm just groping on that one).
