M
Minion
Blow Me !!!
leddy said:If you're tracking multiple instruments in the same room and need some isolation, if the room sounds bad, if you use coincident micing techniques, etc. you're not always going to reach for omnis.
That is what Isolation Booths are For.....
a Single Directional Mic isn"t going to do you much good if you are trying to Capture the sound a several Cymbols that are spaced apart on a Kit...You will hear the Cymbol Closest to the Mic the Loudest because of Proximity effect.....
If you Mic each Cymbol seperately with a Directional Mic then that would Work and help get rid of Transients if there are several Instruments being recorded in the Same Room but that wouldn"t be what you would call Overheads but more of a Close micing situation.....don"t you think??
don't worry, I hold it above my nose, so no spittle is deposited), then a white noise test. Matching takes about 1/2 hour for a batch of 16 to 20 mics.
). Perhaps I am being naive, but in these halcyon days nobody really asks why the mic is glued into an XLR connector, and I'd like to keep it that way
