B
bdoughty2005
Greetings, all.
Hats off to everyone here as I introduce myself. I'm new to the world of semi-pro analog recording and this is my first post here. I have a problem which I've been banging my head on for a few weeks now and decided it was time to share it with others who might enjoy a puzzle.
A few months ago, I purchased a Tascam MS-16 that was reported to be "working" by the seller. He did several recordings on it himself and claims they sounded good.
I have recently had a chance to test it out and found that indeed it seemed to work, at least with a simple record/playback test using a microphone and talking. The speech sounded good on playback, but I found that the input/output levels were way too hot on certain channels.
I don't have a test tape yet, so I thought I would do a poorman's calibration on the hot channels by recording and playing back a test-tone and adjusting the record-playback levels until the input meters matched the input level and the output meters matched the input meters.
I noticed right away when applying a test-tone that there was significant signal degradation on playback: dropouts, and a sort of broad-spectrum noise that sounds like pink noise. This problem occurs on every channel.
Following is a link to a sample, where the first 8 seconds or so are monitoring the input, and the rest is monitoring the repro head. As you can hear, the first 8 seconds sound fine, so there does not seem to be a problem with the input/output amps. The problem is only noticeable when playing back the recorded signal. Replaying the same section of tape yields the exact same signal, so I have concluded the problem is in recording. This was recorded using an Ampex 499 tape the the seller gave me. Again, what you hear on this sample is virtually the same for each channel.
(http) audio.wdoughty.net/499-Tr1-1174hz-8secs_input_remaining_repro.mp3
(sorry the BBS is not letting me create actual links because I haven't made enough posts yet. I'm having to put the parentheses to trick it.)
Next is a link to a sample I did using a brand new RMGI 900 tape. It's about a minute long. You can hear immediately that the problem seems worse. The dropouts are extended and more pronounced and the noise seems louder. If you listen all the way through, you'll hear things get really bad before the end with one dropout that is almost total signal loss and only gradually improves over the course of about 20 seconds or more.
(http) audio.wdoughty.net/RMGI900-Tr1-1Khz-Trimmed.mp3
There are other test samples if you go to audio.wdoughty.net. They include different test-tones and samples from track 4 also. Low frequency test-tones reveal the noise better because the tone is less discernable. Interestingly, the higher the test-tone frequency, the higher the frequency band of the noise.
The test with no test-tone reveals no dropouts as expected, but I find it interesting that it reveals no noise either. I'm wondering if the problem could be with the bias circuitry or the bias oscillator, but those circuits are individual to each channel and it seems unlikely to me that each card would have degenerated in such a consistent fashion. Perhaps not. If I had a known good channel card, it would be easy to test that theory.
I've inspected the heads. Though I'm no expert, I've read the articles on JRF's website and in my opinion, there are no obvious signs of excessive wear or damage on the heads.
I've inspected the tape path also. There seems to be a very slight curl at the bottom of the tape as it passes over the first guide before the record head. When I first noticed this, I thought AHAH! But I've tried pressing the tape to the record head with a queue-tip as I'm testing to ensure good contact and the results are the same. Besides the curl only affects to bottom of the tape which is channel 16, and the problem occurs, of course, on every channel. I don't want to gloss over this prematurely, but my instinct tells me it is not the primary cause of the problem.
I hired a couple of techs to come look at the machine. They weren't able to do much trouble-shooting of the channels, because I don't have an extender card. They didn't have any direct experience with MS-16's either. They thought the problem might be due to the age of certain capacitors. ? They also tested the power supply rails with an oscilloscope. One of the DC voltages showed minor fluctuation. I saw it myself on the scope, but they had to zoom WAY in before it was noticeable. They recommended replacing all of the capacitors in the power-supply but did not have any confidence that doing such would fix the problem. They said it would cost on the order of $1000 to do that. I don't have that kind of money, and even if I did, I'd want to get a second opinion. Does it make any sense that a fluctuation in the DC power would cause a problem only with recording?
I tried adjusting (sweeping) every pot on channel 1's Rec/Playback card. While they all have the effect you would expect, none seem to affect the intensity of the dropouts or the noise.
The machine generally looks to be in good shape. The transport works fine. The cards are generally clean and look to be in good condition (there are no blown-up ICs like Ethan describes in his MS-16 story!).
I don't have any advanced testing gear like an audio-meter or oscilloscope. I wouldn't know what to test if I did but if someone had a suggestion, I would look into acquiring such gear.
The fact that the problem occurs on every channel suggests to me that it might be caused by something common to all channels. The elements that that I understand to be common are the headstack, the transport, the tape itself, and the power-supply. Am I missing anything?
My hope is that one of you veterans with experience might be able to listen to the samples and recognize the problem. Or, perhaps, point me in a good direction for further trouble-shooting.
I'd be grateful for any feedback.
Best regards,
Billy Doughty
Best regards,
Billy Doughty
