JTC111
Active member
I've got PT 7.4.2 with MP Toolkit. Does anyone know if that includes the "mp3 option"? And if it does, where do I find it?
I believe it does. The install stuff for it should be on your protools install cd. Correct me if I'm wrong!
Really? So when it says "pro tools mp3 option" on the music production toolkit features list that just means you have the *option* to buy it for extra if you want it???
Weak! Then again, just put it in itunes or get yourself a free lame encoder.
The music production toolkit does include the ability to import/export MP3s.
Sweetwater told you wrong
http://www.digidesign.com/index.cfm?langid=100&itemid=4865
Pro Tools MP3 Option
By including the Pro Tools MP3 Option, the Music Production Toolkit makes it easy to listen to a new mix on a portable device or quickly share it with other band members without having to use a separate application.
Yikes...$495...what about the $20 mp3 option? Can you import with that?
You CAN import mp3's WITHOUT the mp3 option. The mp3 option allows you to export as mp3.
On a side-note, it uses the Fraunhofer encoder algorythms, which supposidly is the best out there!
