T
Tram
Hi
New to the forum and would appreciate your thoughts on my current dilemma.
I started recording using a Tascam 688 and then moved to a Yamaha AW16g since 2003. I find the AW16G frustrating because of the menus and miss the hands-on way of doing things with an analogue mixer. I've been looking at hard disk recorders (such as the Alesis HD24, Fostex D1624 and an external mixer) and wondered what is the simplest method for recording and mixing without using a DAW. From what I've discovered searching online, it seems quite complicated using a hard disk recorder, such as the HD24, with a separate mixer - bearing in mind, I've been using portastudios.
Typically, I record acoustic drums separately and fly them on to the AW16G. i then overdub various guitars, keyboards etc. I've had a look at Sonar, Ableton Live and ProTools and don't like the user interface. If I have to use a DAW, is there a very simple DAW that just behaves like a multitrack recorder which then feeds into a mixer?
I'd really appreciate your advice.
Thanks
Martin
Thanks
Martin
