A
ap
Member
Seems like all the recommended boards these days have onboard audio. Is this bad?
Is firewire better supported on the board or PCI card...or is mobo firewire even available? The ASUS site doesn't mention it on the P4C800-E deluxe, but www.tomshardware.com says it's on there.
What happened to ultradma 133 harddrives? Alot of the ASUS mobos only mention 133 on the raid controller. Does this mean you have to run RAID to use 133?
What's the latest word on SATA vs. PATA? After quite a bit of research, I still can't figure it out other than the SATA advantages of hot swapping and smaller cables.
Thanks.
Thanks.
