A
antman
i got a monster power pro 2000 but i thought these things were suppose to keep 120 volts going through all the time......cause i notice my speakers get real hissy when it drops to like 114 volts...whats the deal?
lizer like the furman AR-15, UPS is different as well although some do both UPS is uninterruptable power supply and works like a battery so that you do not loose power, if you are getting a hissing noise over change in voltage it would more often than not be a result of any digital pieces being in the signal path like fx and so on as they are not as tollerant to low voltage situations. The Monster has power filtering and surge suppression only. Also relatively stable voltage still varies some so anywhere from 110-124 is normal to see. If its dropping down you may be drawing too much current from the circuit to begin with.oh so if i had a ups that would not happen.........hmm maybe i look into one
Bottom line is that unless you want to spring for a true line conditioner, you should fix the power supply in your amplifier (or powered speakers). Heck, even some line conditioners won't help you, as the first one I checked listed its output as +6 to -12%. That translates to 102-124VAC. YIKES! Even that Furman listed above would barely do it, and only then if their 120 means 120 and not 117....
Fix the speakers. That shouldn't happen.
