Scooterj
I have just learned what the monitoring modes do in my Reaper DAW. What I do not understand is what the monitoring with the Focusrite 2i2 gives me.
Normally I have my instruments going into the 2i2 interface, amp sim, and DAW and listen to them and and other audio tracks on my PC via studio monitors hooked up to the back of the Focusrite.
I am not used to using headphones, but will want to when I start recording my acoustic guitar with a LDC mic.
As I understand it, if I leave the Focusrite monitoring OFF, but have my headphones plugged into the Focusrite, I will hear playback from my DAW and my instrument input but AFTER the signal has gone into the PC and my DAW and then back out again possibly causing latency.
If I have Focusrite monitoring ON then I will hear my input instrument directly without any latency, but can still listen to the already recorded tracks in my DAW at the same time
Do I have this correct? Is it recommended to use direct monitoring on the Focusrite? Does it differ for guitar vs vocals?
Also I just realized that when I plug headphones into the 2i2, the studio monitors continue to sound and are not turned off and turning down the PC volume turns done both the monitor speaker volume and the headphone volume. Hmmmm, clearly I don't understand something here.
Thanks for helping me understand best practices.
