I have no idea what the article is trying to suggest (6dB boosts at 100Hz?!?) but it has absolutely nothing to do with parallel ("New York") compression.
He's just spamming his beats for sale.....
But it (the blog post) still has absolutely nothing at all to do with parallel compression. And personally, I find it a rather ---- irresponsible (?) thing to suggest something as radical as 6-8dB boosts or cuts to *anything* without an awfully good reason for it (as opposed to suggesting that it's actually a decent idea).you use the eq in order to make the drums come out in the mix.you dont need to use it if you don't like it....
Yeah, sorta figured that after reading a couple more blog posts that made about as much sense as this one.He's just spamming his beats for sale.....
Try what - The article that has nothing at all to do with the title?You can try it....it's working!!!!
Dont tell me that the article has nothing to do with the title...
C'mon man.the title is N.Y Compression,and in this article i explain how to do the parrarel compression.The equing is just an additional thing
This is the whole article as I see it on the page:C'mon man.the title is N.Y Compression,and in this article i explain how to do the parrarel compression.The equing is just an additional thing
There's not a word in there that has anything to do with NY style compression -- Or compression for that matter -- except for "use a compressor" and then the rather subjective and potentially unusual suggestions about A&R -- and then later a single reference to "moving the fader of the compressor" (whatever that means) "till the drums sound nice" (snip).Mixing Techniques(New York)
N.Y.(New York) is a drum mixing technique that has to do with compressing the drums.
HOW TO DO IT
Send your drum tracks(kick,snare,hi-hat,tambourine,etc.)to a stereo track
Use a Compressor and adjust it with the fastest attack and slowest release
Use a parametric Eq.
Select a peaking bandtype with a narrow Q.Move it at 100 hz and increase the gain about 6-8 db
Select a peaking bandtype with a narrow Q.Move it at 10000 hz and increase the gain about 6-8 db
Move the fader of the compressor track till the drums sound nice along with the other instruments.
You can also send the bass to the compressor track for a bigger and phatter bass.
