dobro said:
More generalities, with no practical comments about the mix...
the current mix is trash. doomed. start over.
track each instrument seperately... meaning: mic up the drums with every mic you've got. make sure and put at least 2 mics 5' or more over the kit and one or two mics in adjacent corners of the room. if it is a small room cut a hole in the bottom of a bucket and put a mic approx. 6' to the front left area of the kit and about 4' in the air.
have the guitarist and bassist play along with the drummer but don't record them... just the drummer. make sure the drummer plays to a click track. make sure the drums are tuned. new heads, etc. tape the heads to eliminate ping. don't muffle them, just enough tape to keep the conch shell howl to a minimum. check the cymbals, too. a good crash fade is easy to hear, if it clips, then clean the cymbals and change the bushings.
if you track the guitar and bass clean (use 2 mics for each - a condenser mic for the bass, btw) then you can easily fix the levels in the mix. get at least 3 takes from both so you can double the guitars and pan the bass where necessary.
track the vocals last. condenser of course. have the singer get as close to the pop screen as possible. easy on compression. you can add that later. get at least 4 takes. when the singer needs to increase the volume or decrease the volume of their voice move closer and farther from the mic, respectively. the more takes you can get the better. cut-paste-copy-paste, etc.
the bottom line is to get as clean and dry of a recording from each instrument as possible. make sure you use at least 2 mics for each. one mic placed at the 4 o' clock position on the amp speaker (and about 1" from the outer ring of the cone and 1" perpendicular to it), and one mic place about 4 or so feet back from the amp and off to the right or left by about 20 degrees. add a 3rd mic in the corner of the room and about 4' in the air. once the mix is done you can add these peripheral mics into the mix to 'enlarge the room'. fill instruments (sax, p'ching guitare, etc.) can be added later. get the meat mix down first.
is that detailed enough?
