GONZO-X
i do not know of a single person who listens to music in mono.
just for balance......
And I know of almost no one whose music listening is done in a room's sweet spot where they can appreciate the stereo image. Everybody I see who listens to music has the stereo imaging messed up either with earbuds, or a boombox on top of the fridge, or behind the wheel of a car, or in a bar with God knows what speaker positions.
Anyway, we're off topic. The thread's about mixing in mono, not listening in mono. There are advantages to checking a mix in mono.
isn't listening to a mono recording thru a stereo playback still listening in mono?
In headphones, yes, it would be nearly identical (except for the +3dB).Yes and no. A single sound source will give a single pattern of dispersion. Two speakers, even if playing the same exact thing, will make different patterns of frequencies bouncing off different walls. You're going to hear things just a bit differently through two speakers as opposed to one (as well as two needing attenuated as they will be louder). The sound itself is not different, but the interaction with the room will be.In headphones, yes, it would be nearly identical (except for the +3dB).
that was supposed to be a rhetorical question.
) More importantly, a lot have people have said (I have found it to be true at least for the things that I do) that if you start a mix in mono, and do most of your EQing and leveling before starting to pan things out, that it is just plain easier to get everything to sit together nicely. Then it's just a matter of spreading things out a bit and maybe carefully adding some special stereo goodies, but then checking back in mono to make sure you haven't ruined everything again. In my experience, it is always easier than starting stereo and then having to make adjustments for mono-compatibility afterwards. There are plenty of folks that argue this point, but it is at least somewhat true that it's harder to hear (for instance) frequencies that might be clashing between two instruments if they are panned far apart.
But as Guitargodgt said above, the f____ idiot might have won a grammy for his song that LOST the lead VOX in mono...so, mixing in stereo alone could still win you a grammy, but only loose respect amongst knowledgeable audio engineers and those few people listening (or take notice) in mono if you mix collapses in mono. (I wonder if the grammy panels check all mixes in mono..lol)
BE AWARE OF PAN LAWS.
if you think your levels are perfect in mono,
then start spreading them out,
everything changes with the balance,
based on YOUR DAW's PAN LAWS
If you break the PAN LAWS is it just a fine, or are the jail terms involved???
Sorry, just liked the way that sounded...
Ok, So, Dave Pensado has recommended on an ITL episode (I think "More ways to widen your tracks" , but not exactly sure which one) that MONO is DEAD...mix in stereo to keep up with the times!!!
Now, The Recording Revolution newsletter I just received says a valuable lesson is to mix in MONO...that dynamics like EQ and maybe compression can create better results when it comes to real world listening - claiming that most don't listen on Head Phones, and don't listen in the perfect "sweet spots" i.e. computer speakers, cars, home audio, or clubs, were the sweet spot is virtually not there. It is quoted in the article "Rather by the time the left and the right speakers sounds reach your ears, they are collapsed into one big mono mix." Recording Revolution
Dave Pensado is quoted on RR website as taking great much of there great advice. I love you both, not picking sides here!!
Is there an objective logic to this truth or is it totally a matter of a personal (subjective) thing?![]()
